The second Wing Tank's Rear Baffle rivet holes were dimpled and not countersunk. All the rivets set perfectly although the nose of the pneumatic squeezer head was ground down owing to the rivets being so close to the flange. Even so, the trailing edge to the rear of the baffle bent out slightly (the picture is not great showing this); a molegrip bended was used to gently straighten the problem.
