Deoxidine 624 A brush applied acid cleaner for use on aluminium and its alloys prior to painting or Alocrom treatment.
Alocrom 1200B A rapid process which forms a protective golden coloured conversion coating on aluminium and its alloys. Outside the UK, the Alocrom ranges of products are marketed under the Alodine trade name.
CM0481968 is a high performance, low VOC, two-component, corrosion inhibitive Epoxy Primer and Surfacer that contains no chromate. This high performance Epoxy primer is intended for use on all types of aircraft and has excellent recoat/intercoat adhesion with Sherwin-Williams topcoat systems
