Brief Description: Fuel and Wiring Routing and Fixtures
Here you can see my choice to use quick disconnects for the fuel lines, feed and return, to allow for wing removal when I trailer the plane to its hanger. You can also see the Weatherpack connectors I use on the wire connections to the fuel tank and strobe lights.
These fuel quick connectors close off on both ends so there is no fuel leakage.
Yes. that's a small piece of carpet in the bottom of the access hole. Why? I dont know, except it looked nice.
Oh, yes I added another access hole in the trailing edge ot the wing. I just ordered two extra covers and made a template from an existing hole and used my hand router to cut them out.
