Ron's Web Site
Date:  5-9-2019
Number of Hours:  4.50
Manual Reference:  Section 7
Brief Description:  Wing Stringers
I made a makeshift support up by the ceiling to hold the logerons (Parts of Fuselage) that came with the Wing Kit to store them out of the way. Began fitting the spanwise wing stringers. I was concerned that the stringers didn't clear the rib web in some positions. I called Van's and asked if this was a problem. They said it was no big deal because even if the did touch, vibrations would eventually cause them to wear their own clearances over time. Not structural.. just a skin stiffener. I modified the curve slightly in some places to make a better fit anyway. Outboard Left stringer is now match-drilled. Three more stringers to go.
Stringers for Both Wings
Stringer Touching Rib.
