Ron's Web Site
Date:  4-29-2019
Number of Hours:  1.50
Manual Reference:  Section 7
Brief Description:  Make Holes for Wiring Conduit
The plans suggest that accomodations be made to run wiring thru the wings for things like Nav Lights, Pitot Heat, Angle of Attack Warning Device, Etc. 3/4" diameter holes needed to be drilled thru each rib between the two largest lightening holes. I made a quick and dirty little jig to insure that the holes in each rib were uniform and lined up. I drilled small pilot holes then enlarged each to 3/4" with a step drill. While working with this jig, I also made the 3/4" holes in the right wing ribs to save time. All new holes were deburred and the Right Wing Ribs were primed.
Jig in Place
Jig in Place
Enlarging Hole with Step Drill
