Ron's Web Site
Date:  4-22-2019
Number of Hours:  2.75
Manual Reference:  Section 7
Brief Description:  Ribs to Spar Assembly
Assembled all left wing ribs to the left main spar. A little confusing at first because some ribs are left and some are right on the same wing. But it now makes sense. Then I added the left rear spar to the assembly. Match drill all the rib to spar rivet holes to #30 and deburr holes. Note the brown stick supporting the center of the spar. At least for now, this removes the sagging downward of the assembly. I have a laser level on a tripod and used it to confirm that the main spar is very straight and true. The adjustable supports insure that the spar has no twist.
Ribs to Main Spar
Ribs to Main Spar
Added Rear (aft) Spar
