Ron's Web Site
Date:  10-4-2018
Brief Description:  DRDT-2 & Alodine Bath
DRDT-2 arrived today. Assembled and aligned using a .027" shim. I made a trough out of a plastic planter by sealing the bottom and drain holes with a rubber sealant. Tested with no leaks. Will use to immerse cleaned parts into Alodine solution - may also be used for Alumiprep.
DRDT-2
DRDT-2
Plastic Planter Trough
