Ron's Web Site
Date:  1-23-2019
Number of Hours:  1.00
Manual Reference:  Section 6
Brief Description:  Safety Wire and Fiberglass Tips
I used stainless steel safety wire on the Trim Tab Hinge Pin... two small hole drilled in the Left Elevator Aft Spar allow the wire to be threaded through then wrapped on the end of the hinge pin... not going anywhere.
The Right side of the Horizontal Stab and the Right Elevator Tips are done except for riveting the HS tips and doing the Bondo thing.
Safety Wire on Hinge Pin
Elevator Tips Done
Elevator Tips Done
