Ron's Web Site
Date:  1-4-2019
Number of Hours:  1.50
Manual Reference:  Section 6
Brief Description:  Starting Fiberglass Work
Starting on the tips of the horizontal stabilizer, I inserted a piece of balsa wood to support the fiberglass and West Systems Epoxy. I got a bunch of 10ml Oral Syringes w/Caps from the pharmacy to measure the Resin and Hardener. It's a great way to measure accurately. The first application is shown in Image 3. I worked on the other end of the HS concurrantly. It's really not as bad I expected, however having to wait overnight for the epoxy to fully cure is a little annoying.
Balsa Insert (To Dam Epoxy)
Set Up for Epoxy
Set Up for Epoxy
First Epoxy/Fiberglass Application
