Ron's Web Site
Date:  12-20-2018
Number of Hours:  1.50
Manual Reference:  Section 6
Brief Description:  Mount Trim Tab - Adjust Servo Op
I temporarily mounted the trim tab to the elevator so that I could connect the servo and test operation. With the clevis connected to the elevator horn, I determined the correct length of the stainless steel pushrod and cut it. Adjusted so that at the center of the travel of the servo shaft, the trim tab is in trailing postion. I connected a 9V battery to the power leads of the servo and tested operation in both directions. Looks good... everything lined up and adjusted nicely. The trim tab will be finished when I get more of the proper pop rivets in the mail.
Servo connected to Trim Tab
Another View
Another View
