Ron's Web Site
Date:  12-18-2018
Number of Hours:  2.50
Manual Reference:  Section 6
Brief Description:  Mount Trim Tab Servo
The trim tab had to be bolted to it's mounting brackets which in turn had to be riveted to the mounting plate. The six center rivet in Image 2 show those flush rivet heads from the outside. One Clevis is installed of the servo shaft and it seems to be lined up very well.
Servo Mounted
Servo Mounted
Outside of Cover Plate
