Ron's Web Site
Date:  12-8-2018
Number of Hours:  4.75
Manual Reference:  Section 6
Brief Description:  Screw Up!
While mounting the Right Elevator to the HS, I slipped with the wrench and made a small tear in the skin (Image 1). After a little thought, I decided to grind out the tear and radius the removed area. I think this is an acceptable solution with smooth edges and not very unsightly. The right elevator is essentially finished and replacement of the skin seems drastic and unnecessary. I mounted the right Elevator to the Horizontal Stabilizer and made necessary adjustments to the height of the bearings to insure there is no binding and smooth operation.
Small Tear in Skin
Small Tear in Skin
Solution to Tear in Skin
Right Elevator Mounted
