Ron's Web Site
Date:  10-18-2018
Number of Hours:  5.50
Manual Reference:  Section 6
Brief Description:  Match Drilling / Deburring
Trip to Florida - No Entries 10-12-18 to 10-17-18.
Inserted more clecos to prepare for match drilling. Match drilled all HS skin holes and completely disassembled HS. Debur all holes and edges of skins. I was interrupted a few times and forgot where I left off match drilling. I should use a piece of tape or something to mark the last hole drilled. I made a little tool with a couple of pieces of skin taped together holding a 3/32" Rivet which can be used to quickly determine if a 1/8" skin hole has been matched drilled to a #40 hole.
Quick Hole Tester
Quick Hole Tester
