The trim tab uses two small foam ribs which are glued in place to add support. The wooden clips shown are in the positions of the foam ribs and will be left on overnight for the epoxy to cure. Note: I am spending much less time working on the plane each day because I'm running out of things to do... the wings will probably not be here until the end of February.
