Ronalds Web Site
RV-14A
Fuel Tanks
9-21-2019
Fuel Tank Bracket and End Rib
There are a lot of logs saying there is leaking here when installing the fuel tank bracket. Just make sure you use the Proseal where those gaps are. It is hard to see the underside of the bracket that is forward in the tank. Proseal is MESSY!
End Rib Aft
End Rib Forward
RV-14A Home
719
Ailerons
Empennage Elev
25
84
Empennage HS
Empennage Rudder
Empennage Vert Stab
Flaps
Fuel Tanks
Primer
Wing Electrical
Wing Ribs
Wing Spars
