Ronalds Web Site
Date:  11-1-2019
Manual Reference:  21-10
Brief Description:  Riveted Trailing Edge of Right Flap
I used the Cleveland trailing edge rivet set to squeeze the rivets. I didn't put the trailing edge on the table, but instead used an aluminum angle drilled for the trailing edge to keep everything straight. This worked very well as you can see with the laser alignment tool.
Laser Straight
Laser Straight
Right Flap Mounted
Right Flap Mounted
Both Flaps On
Both Flaps On
