Ronalds Web Site
RV-14A
Empennage Vert Stab
11-20-2018
Rivet Front Spar
I riveted the doubler onto the front spar. You want to make sure you rivet flush aft as in the pictures below. Since the mounting flange on the fuselage will attach to the aft of the spar, that part needs to be flush.
VS-01401 Front
VS-01401 Aft
RV-14A Home
719
Ailerons
Empennage Elev
25
84
Empennage HS
Empennage Rudder
Empennage Vert Stab
Flaps
Fuel Tanks
Primer
Wing Electrical
Wing Ribs
Wing Spars
