Ronalds Web Site
RV-14A
Static air installation
Use proseal with the Cleveland's static port. This turned out great! Highly recommend this over the rivet Van's supplies. The method Van's uses is perfectly fine. I just like the look of this static port better.
Air Tube routing
Cleveland's Static Port Inside
Cleveland's Static Port Outside
RV-14A Home
719
Ailerons
Empennage Elev
25
84
Empennage HS
Empennage Rudder
Empennage Vert Stab
Flaps
Fuel Tanks
Primer
Wing Electrical
Wing Ribs
Wing Spars
