Ronalds Web Site
Date:  5-6-2019
Number of Hours:  8.00
Manual Reference:  15-04
Brief Description:  Riveting the Rear Spars
Riveted the rear wing spars to the ribs. Some of the rivet had to be shot with the gun instead of the squeezer. The critical hole was reamed with the 3/8 reamer purchased from Cleveland Tools. I wanted to make sure the hole was drilled very perpendicular to the spar. I used a small drill press mounted on the bench with the spar leveled.
Inboard rivets
Inboard rivets
Outboard rivets
Outboard rivets
Critical Spar Hole
Critical Spar Hole
