Ronalds Web Site
Date:  11-12-2018
Number of Hours:  8.00
Manual Reference:  08-06
Brief Description:  HS rib deburring and straightening
It took a while to use the scotch brite pad to roughen the surfaces of the ribs for the primer. Also had to make sure the ribs were 90 degrees and the fluting made all the holes line up. The forms to help build the HS were constructed with time in mind and made close enough with gorrila tape surfaces.
Prepping
Prepping
Sanding
Sanding
Rib forms
Rib forms
