Today I added a second floor to two of my workbenches to use as wing stands. Then I leveled my fuselage. Whenever you need to make sure something is absolutely level a water level is the way to go. It's much more accurate than the traditional bubble level and can be used over long distances. After the fuse was perfectly level I slid the wing in place and used threaded rod to hold it in place.
