Today I added the pieces that go on the bottom of the fuse directly aft of the exhaust tunnel and below the front doors. The pieces that go under the doors are optional and fabric can be used instead but this could be a significant wear location from people entering and exiting the airplane so I decided to use them. I cut the panel aroung the shock struts oversize and will fabricate rubber seals that will close off the area around the struts.
