The rear door skin is complete. The framework for the rear window has squared off corners. I cut the door skin rounded around the window to give a better appearance. The third picture shows the door latch without the door skin on. The latch is inserted into the tube then the small tabs are folded dowd to hold the plunger and spring in. I found out the hard way that if you folded the tabs down 90 degrees then they would break off. Thus the ones you see here are only folded down about 45 degrees. There is a washer and a spring that are being held in place by the tabs so it isn't neccessary to fold them any further than they are now. This probably won't make sense to you unless you've seen one up close.
