The strap shown in the picture is not shown in the plans but it is recommended by AviPro and the designer Bob Barrows uses a similar version on his airplane. If the cable shackle is connected directly to the rudder arm there is some interference between the shackle and arm when the rudder pedal is pushed all the way foward. This strap eliminates that problem. The bolt holding the strap to the arm is loose enough that the strap can rotate with the movement of the rudder pedals. A drilled bolt with a castle nut and cotter pin are used to secure it.
