This is the top of the boot cowl the goes between the firewall and the instrument panel. I made three templates before I got one that was acceptable to me. The problem is cutting around the two support tubes that go from the wing to the front of the fuselage. Hopefully by taking extra time on the patterns I will only have to cut metal once. It's really not neccessary that the fit around the tubes be so tight anyway. Theres a lot of heat behind the instrument panel that needs to be vented anyway.
