Even with slots cut in the floorboards there will be no way to remove the floor around the control stick without removing the stick assembly itself. These are also the floors that will have to be removed to service the landing gear strut. At the suggestion of another builder I will install nylock nutplates to the metal tabs that the control stick assembly mounts too. This should make removing the stick assembly relatively pain free. The floorboards at the front stop just aft of the rudder pedals. I put a 1/2" lip on the very front to keep things such as pencils from falling down into the belly of the airplane.
