Brief Description: Wing trailing edge and interior control surface pa
The wing has been turned back right side up. I trial fitted the pulleys and aileron bellcrank. I learned from the first wing that the pulleys and bellcrank interfere with riveting the top skin down so I trial fitted all of the parts then removed them. I also installed the two trailing edge ribs and skin at the root end of the wing. I'm now ready to rivet the top skin down.
