More of the same. Fitting the cowling. I reworked the mounting to get more spacing between the prop and cowl. When I buttoned it all up it was closer than I wanted. Now is about perfect. I also cut the opening for the oil cooler air. I need to clean it up a little. I'll have some cosmetic stuff to do to it when I'm all done .. going to cover all the rivets before I get it painted.
