I mounted all the instruments in the panel today. Before mounting the turn indicator I made sure the fuselage was level so it would read right. I have a few more switches and breakers coming. I spent some time thinking about the wiring. I think I'm going to use a keyed on/off switch for the master and a push button for the starter. Next I started on T14 .. the tail tips. I wasn't sure if I'd do them now since I want to get them painted with the rest of the fiberglass by a body shop .. but I can fit them and then rivet them later.
