Brief Description: Finished tail, started instrument panel
First off I finished making and mounting the farings for the tail. I'm not totally happy with the right one .. and will probably make a new one at some point. I installed the rudder cables and hooked them to the rudder. I installed the trim cable. I used a cable stop instead of just making a "Z" bend in the end. On my other Sonex I had this Z pop out a couple times and ended up changing to a cable stop. I then started laying out the instruments in the panel. I need to make the hole for the transponder yet .. I forgot to take the template to the hangar. The switches will go above the EIS .. breakers above the Comm/Xpndr. The starter and mag switches clear to the left of the ASI.
