Brief Description: Horizontal and vertical stabilizers
Today I worked on mounting the horizontal stabilizer and drilling the skin on the vertical stabilizer. Everything went together fine .. but when I bolt the vertical stab in place I'm getting a little rubbing between the arm on the elevator horn assembly and the vertical stab spar. Everything measures fine and I have 3 1/4 inches between the vert spar channel and the main spar on the horizontal one. I'll most likely unbolt it, move it forward about a sixteenth of an inch and go to AN5 bolts to take up the area from the two smaller holes. At worst .. it'll be stronger.
