First I ran the cable housing for the trim so I could get the location to anchor it in the cockpit since I moved the trim lever forward. I installed the fuel level probe in the tank .. and mounted the control unit under the instrument panel where I could get to it to calibrate it. I made a bracket to mount the headphone jacks on. I cut out some outlines of the instruments and spent some time looking at layout on the instrument panel. It's gonna be a tight fit. I think I'll end up putting the GPS on a Ram mount somewhere.
