I pulled the landing gear mounts, the seat, misc other stuff out. I'll put the gear mounts back in after the wings are completed and rigged. I painted the inside of the cockpit. I decided on a metallic charcoal gray since it won't show scuffs as much and it'll match the interior I ordered from Sonex. I mounted some of the fittings on the fuel tank. I riveted the front brackets on the glareshield and painted them flat black. I need to put some fuel in the tank and let it set to be sure I don't have any leaks.
