First off I put together some saw horses using lumber I got last night. It'll be way easier to deal with the fuselage if I can get all around it. Then I worked on squaring up the front section. I got delayed a little when I dinged the top web on the cross tie box while triying to trim it to fit and had to stop and make a new piece for the top of it. I got the box and front fit and square. I then drilled the bottom skin and cleco'd it on. Now to make sure the top matches the bottom and the whole thing is square.
