I finished installing the remote for the ELT. I'm waiting on a longer antenna cable to get that routed and hooked up. I also need to do the wiring to hook the GPS output data to the ELT, but I have a couple questions on that I need to resolve. I started looking at the wing. I spent some time studying the plans and getting a mental picture of it all. I layed out the spars overlapped and made sure the pilot holes lined up. They're perfect. Then I made the angles that go on the end to mount the wing tips. I then started on the 1 inch thick blocks that the pins go thru.
