Cleaned and smoothed all mating surfaces Cleaned up some rough spots in the valve guides with a very fine emery cloth. Installed the main bearings. Installed the cam bearings. Set the crank into the block. Installed the other case half and checked for interference as I slowly rotated the crank. Found a couple spots suspect and market them with a felt marker.
