I installed the drip pan for around the filler neck that I had made previously. I still need to seal it. This will keep overflow from running into the cabin. I worked a little on polishing. I also worked on getting together the info to make a wiring diagram. I drew it all out before I wired it .. but it's on scratch paper.
