Today was a misc day. I put on the Sonex decals I'd ordered. Then I did a little polishing to see if some bad spots were going to come out .. I think they will. Then I worked on the interior. I fit the glareshield cover and made holes for the compass and the GPS mount. I velcroed it down. I worked a little with brake line routing so I could put the side panels back on. Then I put the seat sling back in. That took quite a while .. something changed in the fit with getting the wings on and everything bolted together. I may have to rework it next time I take it out. Also .. the back side of the rivets holding the front hinge on sit high enough to make it very hard to get those pins in. I may change those to solid rivets. I'm not going to worry about it till I have to take the seat sling back out.
