Rogers Sonex Site
Date:  11-27-2012
Number of Hours:  7.00
Manual Reference:  SNX-W07
Brief Description:  Wings - skins
Today I deburred, primed and rivetted the upper and lower skins
on the right wing. I then built a jig for holding the left wing in place
resting on the rear spar so it would be easier to work with the leading
edge skin. I was careful to shim it straight .. using a level and a plumb line on the tooling holes on the ribs to make sure there was no twist. I think this is going to work very well .. giving good access to both sides without moving the wing around. I fit the leading edge on and drilled several of the holes on the top side to hold it in place. After pulling it tight with some tie down straps it looks like the holes on the other side will match up good.
