I finished installing all the fresh air vent parts. Then I fit everything together again and drilled the glareshield. Everything went together good and should be ready to rivet in place. I'll drill the two angles that keep the tank from sliding back with everything in place so it fits snug. I worked on installing the cable housing for the trim cable so I can make a clamp for it with my relocated trim lever.
