Finished making new flap detent angle with more notches and added the trim lever to it. This will get the trim lever forward of the interior side panel I got from Sonex. I don't want to have to cut it up. I worked on the fresh air vent system. I'll put the eyeballs under the instrument panel on each side. I added a couple pieces of channel to mount the eyeballs to that will do double duty as wire carriers.
