Today was another misc day. Worked out placement of the mixture and throttle. Made some ports in the firewall for the mixture and throttle cables .. similar to what I did for the wiring. I worked some on figuring out a catch pan around the filler neck on the gas tank. I started making a different flap detent angle .. with 3 settings and better defined detents so the lever won't pop out. I'm also going to move the trim lever forward a little. I never liked it where it was in my other Sonex.
