Today I worked on the rudder pedals. Cut a recess in the blocks to clear the weld close to the ring end of the rudder bar. Space available was less than an inch. I also removed the paint on the areas that go in the block. I finished fabricating the other brake pedal. Then I mounted it all in the fuselage.
