Rogers Sonex Site
Date:  8-16-2012
Number of Hours:  6.00
Manual Reference:  SNX-F09/C07/P32
Brief Description:  Aft lower cabin, motor mount
First I finished up all the bolts and nuts on the bottom skin that I rivetted yesterday. Then .. since I needed to turn around the fuselage I went ahead and mounted the motor mount. I made some .060 shims and used those and it came out good. I just bolted it on temporarily since I need to make the hole for the steering linkage in the firewall before I mount it permanently.
Next I needed to flip the plane around so there's more room for the wings when I get them built. It keeps getting heavier as I put stuff on it .. so now's the time. The trick was doing it alone. I came up with using the engine lift since it has wheels. The tail is light and easy to pick up.
Fitting the engine mount
How to move fuselage alone
