I spent a good portion of time measuring and adjusting to make sure the measurements across the top matched those across the bottom. Also checking to make sure the fuselage is square. When I felt it was, I started working on drilling and riveting the verticals and cross ties. I'm deburring and priming the mated surfaces with zinc chromate as I go. Before closing up the areas that aren't going to be accessable, I'll coat them with a thin coat of primer. All considered, a fairly productive day.
