Dimple the 603. It is easier to do now before the 609 is riveted into place.
The HS 411 assembly is made up of the 2 HS-411PP brackets and the VA-146 bearing. It is riveted together. it is then clecoed into place and the holes are drilled to #12 for the bolts that retain it.
