Rivet on the front spar statring at the intersection of the 707 rib and the 702 front spar. work twords the tip. then start at the same place and work aft. Rivet the 707 to the skin. Rivet with the squeezer the 706 and 708 ribs leaving the holes open for the fairing. Attach the rear spar and squeeze the rivets that attach the skin to the rear spar.. Rivet the 708 and 706 to the rear spar. Blind rivet the 707 to the rear spar.
Bottom view of Vertical stabilizer before it is riveted on
Front spar flush rivets
A look inside the Vertical stabilizer at the rivets set in the 707 rib,702 front spar and skin.
