Taupo Bearhawk
Date:  12-17-2014
Number of Hours:  12.00
Brief Description:  Ailerons under way
Have made a really good start on the ailerons in the last 2 days. The first one is drilled and ready for priming.
I did make a discovery today though, that has set me back some. I neglected to put a proper 5/8" flange on the gussets in the flaps. Looking at the plans I realised my mistake. So today I drilled out one of the corner gussets from a flap to see how challenging it will be. Not too bad as it turns out, fortunately! So I cut all the new gussets today and will use the old ones to match drill for the already complete flaps. Then I will bend the required flange and reinstall.
I will wait for the long reach squeezer yoke to arrive though, so I can make a good job of the new rivets.
Another transgression has been getting the gussets switched around on the ailerons. Fortunately I discovered this before riveting! The inboard gussets were towards the wingtip and vice versa. No harm done and the new gussets are in place.
First aileron nose skin clecoed on the bottom
Nose skin all drilled and now receiving gussets.
Bottom of aileron getting gussets.
