Tonight sat in the lounge and marked the centre of all the nose and centre rib attach angles for the main spar. These marks will be used to line up the angles to attach them to the spacer bars/spar.
I also laid out all of the nose ribs at their relevant locations on the spar and marked them for cutting to length. 1/4' off for all locations where there are 2 capstrips, and 1/8' off for the single capstrip areas.
Also lots of washing of stiffener angles. The washing is pretty arduous! They are being prepped for acid etch and priming....
