Brief Description: Rudder lite and headset brackets.
Well, I spent about 1 1/2 hours installing 2 headset brackets ands headset jacks. Went on to wiring and fitting the rudder light assembly. Drilled an opening in the rear of the fuselage for the wire loom, installed a grommet, then proceeded to fit and adjust the ass'y. On and off many times until the wire loom was clear of any chafing situations. Lots of shrink tubing used. I then installed the 22 screws and tested the strobe and position lights. All worked great.
